Re: Farmall Steering Shaft Grease Seal
Posted by Janicholson on May 29, 2010 at 14:14:40 from (64.61.211.18):
In Reply to: Farmall Steering Shaft Grease Seal posted by Steve Sch on May 29, 2010 at 13:10:06:
A driver can be purchased, (or made with a lathe) to be about .010" smaller than the OD of the seal.
Make it as long as you can and still have room for tapping it into position. It must be perfectly flat to the bore when starting the insertion, and if cocked at all start over. Putting a swipe of grease on the outer edge is a good idea as well.
Look at the bore and make sure there are no burrs or lips from shaft removal in it before starting.
THey can be difficult to start. Jim
