Re: Farmall Steering Shaft Grease Seal
Posted by stevesch on May 30, 2010 at 14:38:00 from (74.113.44.139):
In Reply to: Re: Farmall Steering Shaft Grease Seal posted by Janicholson on May 29, 2010 at 14:14:40:
Thank you Jim - I"ll try again. I think that part of the problem is that the new grease seal is very flimsy compaired with the original seal. Yes, getting it started is the trick part. Steve.
