Re: Super C, Brace between front end and bell housing.
Posted by Scot in pa on May 31, 2010 at 17:14:28 from (68.28.104.229):
In Reply to: Super C, Brace between front end and bell housing. posted by DFZ on May 27, 2010 at 14:51:32:
Do you have a welder and torch, and room to modify the left one to give you some clearance under the air cleaner? Cut a section out, then weld another piece of rod to the bottom of it. Or make a new one, where you drop the rear rod down on the mount, to give you more air cleaner clearance.
