Re: Super H hydaulics weak?
Posted by mkirsch on June 01, 2010 at 10:24:09 from (64.80.108.57):
In Reply to: Super H hydaulics weak? posted by RTSMikeM on June 01, 2010 at 09:44:02:
First off, what kind of pump does the tractor have, belly or live? That was a transition year for the H-series tractors, so it could have either.
Second, was the second load significantly larger/heavier, or possibly wetter than the first?
I take it after you tipped the trailer up some, the tractor was able to finish the job?
Did you try revving up the tractor's engine to increase pressure?
You really need to pressure test the system with a gauge. A belly pump will produce around 800PSI, and a live pump will produce around 1250PSI.
