Super H hydaulics weak?
Posted by RTSMikeM on June 01, 2010 at 09:44:02 from (70.97.180.27):
I've got a 1953 Super H.
I'm trying to determine if there is something wrong with the hydualic pump.
Last night I hauled two loads of dirt on a tip up trailer with cylinder underneath. The 1st load dumped just fine. 2nd load tractor could not dump.
It made the usual pump noise...but nothing moved.
Didn't lug the motor at all.
Finally I "helped it" but using bobcat to lift the front up a bit so tractor could handle it.
Is there anything that could be wrong inside the pump or need replacing? Are there tolerances that must be tighter? The pump oil level is fine.
Adjustments?
Thanks!
