Re: cub plow, wont, need some help
Posted by Jg20601 on June 01, 2010 at 21:32:48 from (63.28.89.169):
In Reply to: cub plow, wont, need some help posted by ericlb on June 01, 2010 at 19:14:25:
Another minor pointer - the 140 that we used for plowing wont go anywhere if the air pressure in the right rear tire is too high. The first time we used it (1978) the tractor would plow about 10 feet, and then bury the right rear tire like it was heading to china.
The mechanic from the dealership came out and after a few hours checked the tire pressure reduced it to 10 psi (was 32)and it did great after that.
This winter when I was plowing snow with a rear blade with it, I found I was holding the right brake down. Put the valve stem at the top to check the air pressure, and when I tried to take the cap off I unscrewed the whole valve stem lol I got it screwed back in just in time - but it solved the right tire spinning looks like it has about 8 psi in it now.
