You problem is more than likely that your plow is worn. I had to weld a piece of old leaf spring on the point of my cub plow to get it to suck in properly. The length of the link to the drawbar isn't critical. I just use a piece of chain on mine. If the plow is working right it will pull itself into the ground, and keep that chain tight. To get max depth with mine, I have the drawbar just about skidding on the ground.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
