Re: My backhoe doesent move anymore
Posted by Jimb2 on June 02, 2010 at 19:32:45 from (99.240.236.11):
In Reply to: My backhoe doesent move anymore posted by Brad Taylor on June 01, 2010 at 15:05:35:
Hi Brad not familiar with 2500B but I believe it is similar to ag 574. You said it had Hi/Lo/Rev and 1 thru 4 trans which is same as 574. Does it have a T/A or Forward/Rev lever on left side of dash opposite side to throttle? Have you checked clutch adjustment? Should be 1/2" or more free travel before it engages throw out bearing. Adjusted by adjustable rods connected to clutch pedal. If it is the clutch it should move in 1st LO and not move in 1st Hi.
My brother's 684 would sometimes not start moving unless you put trans in N and released clutch and then depress clutch again and put in gear. We changed clutch but didn't fix problem. Had T/A replaced by eliminator shaft and that fix problem.
Hi side of T/A clutch relies on hydraulic pressure from a small hydraulic pump in bottom of torque tube.
JimB
