Re: leak after changing my International 240's trans fluid
Posted by GA Dave on June 03, 2010 at 19:13:47 from (72.152.215.155):
In Reply to: leak after changing my International 240's trans fluid posted by Chris Bordeleau on June 03, 2010 at 11:56:43:
Look to the right of the PTO shaft about 2 o clock. The plate has a hole in it to access a plug. Takes a 1/4" extension. On level ground remove the plug and quit filling when it reaches this level. Be sure to replace the plug. I used 90 WT gear lube in my 240. The hydraulics do not use the trans/rear end fluid. Seperate reservoir is in the frame under the fuel tank. David....................
third party image
