Re: leak after changing my International 240's trans fluid
Posted by Chris Bordeleau on June 04, 2010 at 06:05:01 from (136.223.19.11):
In Reply to: Re: leak after changing my International 240's trans fluid posted by GA Dave on June 03, 2010 at 19:13:47:
Thanks... when I added it I did add to the overflow plug then let
it sit for an hour and weep the excess...
It's also possible that as farmer_adam says it could be over full
from oil weeping down from the gears... I'll check that next time
I'm down
I think I am going to run the rest of the summer with the hytran
and just check the level then come fall switch it over to 90wt...
btw that is one clean tractor... I consider mine clean but yours...
wow...
do you have a pic of the back from a little more left... on ours
there is a lever that dangles that looks like it should hook up just
behind the cylinder... have no idea what it does and where it
looks like it should hook up it does not reach... I'll take a pic and
create another post if you have no idea what I'm talking about...
if you do know what I'm talking about what is it supposed to
do???
thanks
