Posted by El Toro on June 04, 2010 at 17:07:09 from (74.103.74.58):
In Reply to: Farmall H Won't Start. posted by Keith Fuller on June 03, 2010 at 20:04:26:
You should check your battery's voltage while a helper makes an attempt to start the engine. Your voltage may be dropping too low for your ignition while cranking if you have a distributor. Since it will start by towing you're not dropping the battery voltage when its towed. I would check the battery's specific gravity using a hydrometer after being charged. Should be in the 1.260 range and all 6 cells should read close to one another.
You need 00 battery cables and don't have them any longer than necessary. Solder the lugs. Clean all surfaces nice and shiny. That includes where your battery is grounded and make sure all connections are tight. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
