Re: Farmall H Won't Start.
Posted by Janicholson on June 04, 2010 at 17:22:56 from (64.61.211.31):
In Reply to: Re: Farmall H Won't Start. posted by El Toro on June 04, 2010 at 17:07:09:
I believe this is the answer you should go with. Wimpy battery cables are historically an issue with 6v systems. 00 gauge cables have wire (not the plastic insulation) about the size of your little finger. It can take 400 amps to turn an engine at 6V, so Kmart cables are not going to make it. (do not discharge that new battery and recharge it)
If it still will not turn the engine it is either a very weak battery, or has a bad cell (it is possible for a new battery to be bad!!!!! Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
