Posted by keithg on June 04, 2010 at 21:24:36 from (173.28.129.191):
Am starting to work on a Farmall M transmission and will be replacing a number of leaking gaskets & seals (front of countershaft, PTO housing, axle carriers to transmission, etc). When reassembling gaskets do you use any type of gasket sealer or cement along with the gasket? If so, any specific product recommendations? Or will the gasket alone be sufficient to hold 80W-90 gear lube? I also will be opening up the belly pump housing with its gasket--any advice about that gasket? Thanks in advance.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
