Re: Gasket Question
Posted by Art Massing on June 05, 2010 at 19:09:26 from (66.103.108.45):
In Reply to: Gasket Question posted by keithg on June 04, 2010 at 21:24:36:
Keith,
I second Rustred on using Permatex Hi-Tac.
I also believe the key to a “No Leak” repair is in the surface preparation regardless of the particular sealer you use. I clean the mating surfaces with mineral spirits and then with denatured alcohol. Then spray or brush the sealer to both surfaces as well as both sides of the gasket material. I have very few leaks.
Good luck with your project,
Art
