Re: Farmall A Tractor Pulling Problem
Posted by Tony (A2, MI) on June 05, 2010 at 08:04:28 from (76.249.45.19):
In Reply to: Re: Farmall A Tractor Pulling Problem posted by Jg20601 on June 04, 2010 at 21:11:10:
Thanks. He did not try applying the right brake. The tires are at about 9psi. Seemed so odd that no one else had issues and he just sat and spun. I am not sure how sensitive they are to weight distribution,but since it is a Super A, it has a bit more weight in the center and no ability to add weight. He weighed in at 2565 in a 2600 pound class.
I guess I'll have to figure out a way for him to practice at home to see if tire pressure can make a difference.
Is it possible something is wrong in the rear end? Is it normal for one tire to just spin. Seems like the other one should be kicking in to try and do the work.
Thanks,
Tony
