Re: H troubles
Posted by Janicholson on June 05, 2010 at 20:03:06 from (64.61.211.179):
In Reply to: H troubles posted by jay Snyder on June 05, 2010 at 17:19:35:
Diagnosis of the fan hub should be one of wiggle motion, and noise. If it does not wiggle when flexed with the fan blades (stopped)
Noise can be spotted with a short broom stick or other stiff rod touching the Water pump body and listening to the other end. Be careflu to not touch moving parts!!!
You might have a leaky needle and seat in the carb letting gas in just enough to load the engine. Removing the bowl and flushing the seat with carb cleaner might help. The idle adjustment procedure is in the archives!! Search for Box
Jim
