Re: H troubles
Posted by CJ_1080 on June 06, 2010 at 05:45:40 from (166.229.49.172):
In Reply to: H troubles posted by jay Snyder on June 05, 2010 at 17:19:35:
All good info! Also check for a loose fan shroud! I had one loose bolt on mine and the intermitant rattle almost put me in the nut house ( I am usually almost there anyway)! Just another area to check. Good luck!
