Re: gasket material
Posted by Jeff Z. on June 06, 2010 at 06:05:45 from (72.228.48.9):
In Reply to: Re: gasket material posted by Jeff Z. on June 06, 2010 at 05:47:34:
Just a note:
Don't smooth out the silicone. Leave it in a thick bead on the oil pan so it will spread evenly.
If it is spread out and too thin in an area it won't have enough material there to make a good even seal.
When you bolt the pan back on the bead will spread evenly and be thick enough to make a really good seal.
