Re: gasket material
Posted by KEB1 on June 06, 2010 at 07:50:00 from (97.124.128.182):
In Reply to: Re: gasket material posted by Jeff Z. on June 06, 2010 at 06:05:45:
When you first install the pan, don't torque the bolts up tight. After the RTV has a chance to cure, then torque to the proper value.
Also, don't just glop it on. If you use too much, you run the risk of a glob squeezing out on the inside & falling into the engine.
Keith
