The Terminal #1 (small spade connector on the side of the alt.) can be hooked to the carb solenoid, but it will still need a diode in it, or a dash light sized bulb type light. This allows exciter current, but prevents feedback to the ignition circuit that could cause it to run with the key off. A 100 ohm 10 watt resistor will also work. The bulb, diode, or resistor are not connected to ground, they are connected with one lead to the alt #1 tab, and the other to the source of 12v. If you use a diode, the Band on the Diode is toward the alternator. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
