Is the tough spot at the same place each time you roll the wheel? Is it in time with anything else you can see or hear? If you block the clutch forward, & put the shift lever in a gear, does this affect the binding as you roll the wheel? Try to isolate between transmission shafts & differential/final drive areas. Sounds like either a bearing has a couple balls out, or there is something like a piece of foreign material in a gear tooth.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
