Posted by Tod Michigan on June 08, 2010 at 12:09:07 from (75.219.100.7):
I was discing with my IH FARMALL 460 DIESEL and a knock suddenly started. Not in the motor. Also, this tractor does NOT have the T/A (Tourque amplifier) on it. The knock sound seems to be coming from the transmission section toward the bottom, where the Counter Shaft is. We removed the belt pulley assembly and any covers over that area to expose as much as possible except the large plate your feet set on when your sitting on the tractor. Noise goes away if I push the clutch in, and goes faster and slower with the idle speed of the motor. We don't think there are any teeth missing from a gear. To remove the sound of the motor, we jacked up the one tire so we can spin the tire by hand to make the noise and we noticed that when the clunk or knock happens, it actually seems to lock or "bind" the gears for just a second and there is a keeper clip on a gear that is in the same place every time the clunk happens. If we use little force to spin the tire and go very slow with turning the tire by hand, what ever it is will actually stops the tire. Understand that to make it do this, we are not turning the tire very hard at all and very slow. If it binds to the point of stopping the tire, we can make it turn again by pushing harder on the tire. Getting ready to crack the tractor in a few days. Also going to remove the deck plate over the differential / transmission section. PLEASE HELP. ANY IDEAS WILL BE HELPFUL. If more information is needed, please email me and I will respond. Thanks for reading. TOD.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
