Re: KNOCK in Trans area of IH Farmall 460 Diesel. PLEASE HEL
Posted by bc on June 10, 2010 at 03:44:00 from (69.151.187.200):
In Reply to: KNOCK in Trans area of IH Farmall 460 Diesel. PLEASE HELP. posted by Tod Michigan on June 08, 2010 at 12:09:07:
Tod, if you really like working on them, replace the bearing only. The chipped tooth may only make a ticking noise you can live with. See if a welder or machine shop can build up the tooth.
