Re: 684 Hydraulics
Posted by richardinnz on June 11, 2010 at 02:59:52 from (125.239.185.11):
In Reply to: 684 Hydraulics posted by VERAGUTH on June 10, 2010 at 15:36:11:
Check the aux levers, they are on your right and low down, I have been called out to some of these tractors only to find a lever has been accidently knocked in to pump, one of the breakdown symptoms was flat battery and the tractor would not start, as the hydraulics loaded it slowed the starting motor.
Another problem was with a new owner and I dicovered (eventually) that a front loader had been fitted at sometime and removed prior to the guy buying it, the out let to the front loader remotes had simply been plugged, instead of the proper end plate being fitted to the tractors remote valve.
