Posted by B.V. on June 11, 2010 at 07:57:13 from (74.174.194.2):
What kind of oil do you recommend for a 1957 cub tractor?, engine, transmission, and rear end. Would 10w30 Pennzoil be good for engine and hydraulic and gear oil be good for the rest? Thanks again.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
