Re: Oil for Cub Farmall
Posted by glennster on June 11, 2010 at 14:25:03 from (76.224.31.75):
In Reply to: Oil for Cub Farmall posted by B.V. on June 11, 2010 at 07:57:13:
didnt see any body respond yet, so i'll give er a whirl. i run rotella 15-40 diesel service in my old gas tractors and they seem to like it fine. the bearing tolernces were a little looser on the old motors, so a little thicker is better. for the hydraulic system i run i-h hy-tran or equivalent, and the differential, 80-90 or 85-140 wt, what ever is on sale. the new lube oils are a lot better than what was available when the tractor was first built.
