Re: Engine guys - need some 806 (diesel) advice
Posted by BarryW on June 11, 2010 at 09:20:00 from (129.162.1.42):
In Reply to: Engine guys - need some 806 (diesel) advice posted by BarryW on June 09, 2010 at 10:29:21:
Is it a special CaseIH tool or someone elses? If you could supply me a manufacturer and/or model number I'll check into it. Do you still need to preheat the gear to reinstall it with the tool? If not, what does it grab onto to push the gear against the press fit?
One thing I'm also curious about is that it sure looks to me like the cam is a tooth off on timing compared to my I&T manual illustration. The tractor seems to run fine with good power, so I'm a little afraid to re-time the cam if I do end up pulling it, but it bugs me that the timing mark doesn't currently line up with the one on the crank gear at TDC. I don't know if the manual has actual valve timing (crank angle at .050 valve lift, etc.) info in it that I could compare against with a degree wheel or not.
