Re: 600 D hydraulic has low pressure
Posted by pete 23 on June 11, 2010 at 10:12:09 from (173.87.0.80):
In Reply to: 600 D hydraulic has low pressure posted by nathon on June 11, 2010 at 10:02:26:
Is the ball and spring in under the plug you bled pump with. Was the snap ring on the piston under the safety relief valve spring retainer. That small valve with ring is actual relief valve, the retainer under spring is to seat on top of relief valve.
