Re: 600 D hydraulic has low pressure
Posted by nathon on June 11, 2010 at 13:18:32 from (216.227.55.31):
In Reply to: Re: 600 D hydraulic has low pressure posted by pete 23 on June 11, 2010 at 10:12:09:
Good questions! Yes the ball and spring are still in the pump. I have seen those fly before. The snap ring is in place on the piston under safety valve spring retainer. If you have any other suggestions I would surely appreciate them.
Thanks!
