330 Utility Clutch t/a adjustment
Posted by nates90 on June 11, 2010 at 19:00:43 from (208.126.133.200):
I have a IT manual and I adjusted the clutch and T/A per the manual. I started it up and tested it and nothing changed....it was not far out of adjustment. The problem is that when I put it in a forward gear it will act just like normal in high and will not change when put in low, but if I pull the T/A lever further back it will make a clicking sound. Then when I go to stop facing up hill, it will not roll backwards and its hard to take it out of gear. It does the same thing in reverse, but just in the opposite direction. I know it sat outside for about a half a year without moving/running. I had to clean the brakes to get it to move. If anyone knows what the clutch and T/A are doing, it would be greatly appreatiated to let me in on the secret....haha. Thanks.
