Re: 330 Utility Clutch t/a adjustment
Posted by pete 23 on June 12, 2010 at 14:46:11 from (173.87.0.80):
In Reply to: 330 Utility Clutch t/a adjustment posted by nates90 on June 11, 2010 at 19:00:43:
No, you don't have to split the tractor, however, that is only a get by type of repair as if that is the problem you really need to replace or rebuild the clutch which does require a split. Have done it a few times though , through the top cover, trick is to get them all even. Lots of things are possible but not necessarilly the correct way of doing repairs.
