Re: 450
Posted by CNKS on June 12, 2010 at 12:39:55 from (216.144.104.128):
In Reply to: 450 posted by wonder on June 12, 2010 at 11:25:58:
If the clutch was working OK and suddenly stopped working, then it is likely not the clutch, as slippage will get worse gradually and occur first in the higher gears. On the other hand, if you mean everything turns with one wheel off the ground, and no noise, then it probably IS slipping and at least the disk needs replacing. So, when you let out the clutch with the engine running and both wheels on the ground, does the engine die or continue running?
  • Re: 450 wonder 19:11:11 06/12/10 (1)
    • Re: 450 Wardner 21:24:36 06/12/10 (0)
