F20 sediment bowl
Posted by bigr on June 12, 2010 at 18:31:44 from (209.225.110.238):
My F20 started leaking gas out of the plug/breather in the bottom of the carb with the gas shut off. I drained the gas out of the tank, took the sediment bowl out of the tank, used carb cleaner, blew it out with air, wire brushed everything twice and it still leaks past when the gas is off, Did I miss something, or is it time to replace it? I believe it's the original from '39.
