Posted by 36F30 on June 12, 2010 at 20:12:21 from (71.214.211.34):
In Reply to: F20 sediment bowl posted by bigr on June 12, 2010 at 18:31:44:
The carb needs some attention. Needle and seat is not shutting off the flow in the carb. The float may be getting heavy or it could just be crud stuck on the seat. Check/clean the screen on the fuel inlet while your at it.
These carbs have a hard time holding back a full tank of fuel when everything is perfect, so its highly recommended to turn the fuel off at the sediment bowl every time.
(some turn the fuel off and let the tractor run until it dies) but if your carb is bad they will still leak off the fuel in the line
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
