Posted by ctallen2010 on June 16, 2010 at 14:42:31 from (173.212.21.222):
I have double checked wiring, it is right. But, it seems the front right light is not making a good connections (when I wiggle it, it goes on and off), when it does go off, the switch starts smoking???? Any suggestions? It has new wires, all connectors are new and tight, heat shrinked, test light shows power etc.... where the light wire connects on back of light housing, is loose, light flicks on and off, I tightened it all up, and the smoking stops, what is causing it, please advise???
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
