sounds like you got a hot wire touching a ground or is the switch the one that came on the A it could be bad or did you switch over to 12 volt and left everything 6 volt / if you are using 12 volt you need a voltage reducer I got mine with a 12 volt and it had one on it and i still use all the old switches but put 12 volt bulbs in Im sure that someone else will have some good input for you just backtrack and recheck everything good luck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
