Just use a Prestone cleaner, or equivalent. HOWEVER, you will not get everything out. That system has 59 years of thick crud in it, and will not come out unless the radiator is rodded by a radiator shop (and will probably fall apart in the process) and the block and head hot tanked. As a compromise I put dilute HCl in my Super H, with the radiator off, then flushed repeatedly with baking soda (Sodium bicarbonate). Merely telling you what I did, not a recommendation. Acid must be neutralized, it cannot be removed with water. It is reasonably clean. Also you should replace the cover/water distribution piece on the left side of the engine. It will be rusted through inside.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
