Re: M Cooling system flush
Posted by Firechief135 on June 18, 2010 at 06:35:09 from (156.142.4.44):
In Reply to: Re: M Cooling system flush posted by CNKS on June 16, 2010 at 17:37:21:
Thanks CNKS!!!
Two questions - if you run dilute HCl thru the block with the radiator off - how do you circulate it? Do you essentially hook the hoses that would go to the radiator together and then run the engine, probably with the thermostat out?
Second - you mention having the radiator rodded AND it will probably fall apart :) Can the shop fix that or is it a new radiator. I would like to take good care of this tractor and am willing to do things the right way - however if I do not have to take much of the motor apart I would prefer not to as it seems to run very good as is.
Thanks for your help and advice,
Brad
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
