the torque amplifier on a 706 is the same unit as used from that tractor all the way up to the 86 series. it is a two-speed transmission controlled by hydraulic clutches right in the front end of the speed transmission (the 1-2-3-4). you shift "on the fly" (no clutch needed-even under load). extremely handy feature. forward is direct drive and back is, i think, approx 1/3 reduction in gear ratio. if you can't tell that it does anything, something doesn't work. it should be a very noticeable change in speed. tough to diagnose remotely- could be as simple as the linkage is disconnected or out of adjustment, or there could be big problems with the ta unit itself.
i wouldn't necessarily jump to the conclusion that your transmission problem is worn gears. they can take a lot of use & abuse, but the shift linkage is much more trouble-prone. sounds like something isn't right in the moving parts on the underside of the transmission cover. i'm sure someone else on this board has more experience in that particular problem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
