Re: 450 motor in 460
Posted by The tractor vet on June 18, 2010 at 21:04:33 from (76.212.236.89):
In Reply to: 450 motor in 460 posted by bob7337 on June 18, 2010 at 18:57:55:
and what do you plan to use for a flywheel and clutch ??????? Fix the engine in the 460 then fix the rear end in the 450 lot less work and ya won't need the extra aspirin for the headaches your about to have .
