Posted by 47H on June 19, 2010 at 07:20:54 from (76.164.179.49):
Problem #1: Started and operated 1948 Cub this morning and it ran fine. Shut if off for a few minutes, now it will not start or run with out the choke rod pulled all the way out. Thoughts?
Problem #2: Been having electrical problems. Had generator rebuilt, new voltage regulator, new mag, all new wiring and switches. Still 6V positive ground. Polarized gen to VR. Was told to switch from 4 postion light switch to 3 position since VR being used instead of cut out. Every thing is wired correctly for sure! Tell me if this is correct; postion 1 of light switch - lights are off, position 2 front lights on dim and back light on, position 3 front lights on bright and back light on. Here is my dilemma the ammeter never shows a charge. It stays at 0 with tractor running and lights off regardless of RPM's. With lights on shows about a 10 amp discharge regardless of RPM's is the correct?
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
