Re: Cub Problems
Posted by Janicholson on June 19, 2010 at 08:01:09 from (64.61.211.76):
In Reply to: Cub Problems posted by 47H on June 19, 2010 at 07:20:54:
Problem #1 is probably a piece of dirt in the main jet of carb (clean)
problem 2 might be that the generator could be a three brush. If it is the third brush needs to be very close the the non movable brush on the side that it will move. If this does not help, or it is a 2 brush, the system might not be charging enough. The bat volts (lights off rpm 2/3 or more) should be 7.1 to 7.3 volts with a fully charged battery. Jim
