Posted by pete7 on June 19, 2010 at 16:36:49 from (71.243.167.6):
My thanks to everyone who replied yesterday to my questions on electrical color codes and wiring up a gas gauge. Looks like I will be continuing to use a stick to see how much gas is left in the tank! I just could not get the gauge to work while in the tractor. Tractor has negative ground and the gauge is for the original positive ground setup. I tried reversing the wires but that didn't do it. However if I took the gauge out of the tractor and hooked it up to a separate 6 volt battery, I could get the needle to move to Full. All I can figure is that the gauge needs a positive ground system. Not sure why polarity is important to a gas gauge since there is just a coil of wire that heats up inside the gauge to warp a bi-metallic strip that pulls the needle from empty to full. Oh well, on to other things. Pete
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
