Re: Update on Farmall 340 Gas Gauge
Posted by Al L. in Wisc. on June 20, 2010 at 20:06:37 from (216.226.92.151):
In Reply to: Update on Farmall 340 Gas Gauge posted by pete7 on June 19, 2010 at 16:36:49:
Pete; I don't see how a gauge can tell whether it is positive or negative ground, other than the needle will go in the wrong direction, i.e. amp gauge. I think your problem could be poor contact around the gas tank opening where the tank sensor is attached to the tank. Mine, I peek in the fill hole. Week before last, I finally burned up all of last years gas. I hope this helps; good luck.
