Re: Super M won't restart
Posted by charlie M on June 19, 2010 at 17:54:15 from (65.37.31.217):
In Reply to: Super M won't restart posted by gatorhide on June 19, 2010 at 17:39:16:
Some places to start - I'm assuming the motor turns over but doesn't start. I would pull a spark plug and make sure you have spark. No spark could be the switch. Also make sure the rotor turns - there is a pin inside the distributor that is part of the drive unit for the distributor - if its sheared off nothing turns and no spark. Its easier to check electrical if you have a meter if you start looking at switches and wiring. If you have spark then I would look for a gas issue. If there is a plug in the carburetor remove it and let the gas run for a minute or so. If it stops flowing you have a plug somewhere - could be the float is stuck, gas line plugged up or possible the inlet in the tank has some junk plugging it. I'd suggest trying these things and get back to us if these things aren't the problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
