Super M won't restart
Posted by gatorhide on June 19, 2010 at 17:39:16 from (24.155.13.131):
I need some help! My 53 super m will not make any sound when I push the starter button. It was running 2 days ago shredding, but had a bad battery-"red top optima; "-no warranty after 3 years-"...The following parts were added:
1 new battery
2 new alternator
3 new push start switch
4 new points,condenser,rotor.
5 new coil w/out internal resistor, but added in-line resistor-hooked it to + side going into coil.
6 Tried to start it by pulling with pickup, but did not fire.
...Do you think it's the on/off switch ?
...Or what ?
...Update Monday, no luck yet.
...Took starter off and will have it checked tomorrow.
...Will post results tomorrow night, THANKS TO ALL !!!!
This post was edited by gatorhide at 19:51:27 06/21/10 3 times.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
