Posted by El Toro on June 19, 2010 at 18:09:51 from (74.103.74.58):
In Reply to: Super M won't restart posted by gatorhide on June 19, 2010 at 17:39:16:
Pull off a plug wire and see if there's a good hot fire to your plugs. If there's no fire to your plug.
You need to to see if you have voltage at your coil. With points open and your ignition switch in the on position use a volt meter or test lite to see there's voltage on both terminals. If there's no voltage you need to check for battery voltage at your switch. Check the terminal on the switch that feeds voltage to the coil. You need the switch on. If there's no voltage you need to check for voltage being fed to your switch. You should have a feed wire that feeding battery voltage to your switch.
Use a separate wire to run battery voltage from the battery to your coil and see if it will start. This will bypass you ignition switch. Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
