If I remember correctly the tractor will still turn over with the on off switch in the off position... The kill switch disrupts voltage to the coil creating no spark which will kill the motor. I don't believe it disrupts cranking voltage.
Were the parts other than the battery replaced prior to the no start problem or after??
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
