Re: Super M won't restart
Posted by gatorhide on June 19, 2010 at 18:44:54 from (24.155.13.131):
In Reply to: Super M won't restart posted by gatorhide on June 19, 2010 at 17:39:16:
...The carb has just been rebuilt by a top notch mechanic with a new kit and new float. The carb works great.
It gets gas, the bowl is full and flowing. It"s not a fuel issue.
It does not turn over at all when I push in on the start button.
Sunday follow up. " Today I checked the on/off switch with a test light and found that when the switch is pulled out/on, that I'm not getting any voltage past the start button.
So it appears that the on/off switch is BAD.
I'll replace that switch and see if she will fire up.
THANKS TO ALL OF YOU FOR YOUR HELP!
I'll post the results tomorrow.....
This post was edited by gatorhide at 17:31:24 06/20/10.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
