Re: 1948 Farmall H hydraulic belly pump, advice ?????
Posted by BruceS. on June 20, 2010 at 04:34:35 from (76.15.41.217):
In Reply to: 1948 Farmall H hydraulic belly pump, advice ????? posted by adam C. on June 20, 2010 at 02:49:17:
The person you bought it from may or may not help you. However, these pumps are quite simple and easy to fix; the biggest thing is time. You will probably have to take the pump out of the tractor (look in the archives on this site- lots of info) replace the seal on the driving shaft, and the seal where the pump fits into the reservoir. About $20 in parts plus yours (or someone else's labor. Parts are available from your IH dealer or Bates Corp.
